Live Tool CNC Lathe: Y-Axis Overtravel Explained
April 21, 2024
Lathe turret diagram showing a Y-axis move that causes an out of travel error
While the concept of having a Y-axis on a multi-axis live tool CNC lathe is simple, the non-orthogonal way the axis moves, and the ins and outs of those movements, can be a little more complicated than expected. So, in this blog I explain the Y-axis movement and how overtravel can occur.
How the Y-Axis Moves on a Multi-Axis Lathe
When we jog the X-axis or Z-axis on a lathe, it is simple to understand how the machine will behave to accommodate those movements. Both axes ride along precision linear rails that stretch the full distance of travel for each axis. The travel for each of these axes will add to the determination of the overall size of the machine itself. The longer the Z-axis travels, the longer the bed of the machine will be, for example. But when jogging the Y-axis, it’s not quite as straightforward (figures 1b & 1c).
Figure 1b: lathe turret and wedge diagram with the X-axis travel direction marked Figure 1c: lathe turret diagram showing the wedge moving along the X-axis slide
On most multi-axis lathes with a Y-axis, the movement is non-orthogonal, which simply put means that the movement is not a linear or perpendicular 90-degree movement. Jogging of the Y-axis is made possible using a wedge design in the machine where the perpendicular travel is actually achieved by moving two separate parts of the machine (figure 1a).
Figure 1a: multi-axis lathe casting with a wedge-style Y-axis, shown without its enclosure
When the control receives a Y-axis movement command, it’s the combined movements of these two pieces that form the wedge that will affect the movement of the tool tip as desired (figure 2a, 2b, and 2c). Again, we ultimately get what appears to be a perpendicular orthogonal movement of the axis, which is made possible by the non-orthogonal movement of the machine components.
Figure 2a: turret diagram with the Y-axis and X-axis travel directions marked Figure 2b: turret diagram showing the two wedge components moving together for a Y-axis move Figure 2c: turret diagram showing the two wedge components moving to shift the tool tip along the Y-axis
Multiple Tools in One Turret Station
This Y-axis motion also allows us to utilize multiple tools in each tool station by providing the ability to shift the axis and teach multiple tool offsets for the same turret station (figure 4a). This capability is not only limited to live tools, but also static stick tooling of both double and quad holders. The quad holders can also expand this multi-tool capability for use on sub-spindle machines as well for secondary operations (Figure 4b).
Figure 4a: EXSYS double live toolholder holding two tools in one turret station Figure 4b: quad static toolholder that holds four stick tools
(Figure 4a by EXSYS Automation; figure 4b by Modern Machine Shop)
Why an Out of Travel Alarm Occurs
Now that we understand what is entailed in moving the Y-axis, let’s discuss one of the issues that can be created by this movement when the turret moves to a designated location for a tool change. Since the commanded position of the X-axis for tool change positions references the tool tip, let’s assume that the Y-axis is NOT at the zero or home position (center of the Y-axis stroke), and the X-axis commanded position is well within the travel limits of the machine. We still get an “out of travel” alarm, causing the machine to stop. Why did we get this error?
The images below should help clarify the reason for the out of travel error. In figure 3a, we see the X-axis at its full travel position, and the Y-axis is at its zero or home position. In figure 3b, we see the tool tip travel to a positive commanded position of Y 50. The turret can easily move to that location by simply sliding along the wedge without the need to move the X-axis cross slide at all.
However, in figure 3d, we see that the commanded position would require both the wedge and the X-axis cross slide to move in order to reach the commanded tool tip position – the wedge would need to move negative, and the X-axis would need to move positive - but the X-axis is at a point of full travel and cannot move any further in the positive direction, so the control will produce the error and stop the machine.
Figure 3a: X-axis at its full travel position with the Y-axis at zero Figure 3b: tool tip moving to a positive Y position by sliding along the wedge Figure 3c: tool tip at the positive Y position with the X-axis still at full travel Figure 3d: commanded Y position that needs X-axis movement past full travel, causing an out of travel error
Solving the Out of Travel Error
If the condition mentioned above was during a machining operation, and the commanded position was out of the travel capabilities of the machine, then a programming correction would need to be made. Or, possibly changing the length of the tool being used or the holder type might both be ways of handling this issue. Either way, it would be up to the program and operator to solve the problem.
On the other hand, if the issue was created while the machine was moving to a designated tool change position, then we do have the possibility of addressing the issue inside of the control software, which is how Hurco has decided to correct the issue. Whenever the control sees that the turret is being commanded to the tool change position, the Y-axis will automatically return to the home or zero location to eliminate the possibility of the out of travel limit error.
