Restart Program Where You Left Off With Hurco Recovery Restart
June 14, 2013
WinMax Recovery Restart screen with the Auto Set Restart Marker softkey highlighted
Have you ever had to abruptly stop your machine in the middle of running a program and wished there was a way to restart the program exactly where you left off, even if you were in the middle of all that code? With Hurco’s Recovery Restart feature, you can!
Starting with WinMax® version 9, the software will automatically insert a restart marker at the exact location of the last block executed before the interruption, which relieves the pressure on the operator to remember (or guess) what block to restart the program.
A Lesson From the Trade Show Floor
Previously, I was in the Hurco booth at the Amerimold show in Rosemont, Illinois. During the show, one of the sales managers wanted to show a customer our Cycle Interrupt mode, which allows the operator to interrupt the machine, jog the table, inspect the part, clean out a hole, etc. This scenario is very similar to recovery restart, except with Cycle Interrupt you never actually exit the “auto” mode.
So, he proceeded to press the yellow "Interrupt" button on the control panel, which caused the Z-axis to retract to its home position and the spindle to stop. He jogged the X and Y axes out of their current position and removed the HSK toolholder from the spindle, just to show that we could in fact do all of those things. Once he clamped the tool back into the spindle, he could simply hit the "Auto" button on the control panel, followed by the "Cycle Start" button, and the machine would automatically reposition the X and Y axes, turn the spindle back on, drop the Z-axis into position, and then resume the program exactly where it was interrupted. Except this time, he clamped the tool in the spindle BACKWARDS.
To recover from the situation above is simple enough, but we would have to enter into Manual mode, which would cause us to exit the current Auto mode necessary for the prescribed recovery of Cycle Interrupt. Nonetheless, we quickly recovered the machine from the mis-oriented tool and were ready to restart the program. However, in the confusion of the situation, the manual button had been depressed too quickly, and nobody noted the current block in the very large mold program that had been running for several hours. Uh-oh!
The experienced NC Hurco users reading this post are no doubt shaking their heads right now because they know that you never stop the machine in a situation like ours without making note of the current program position if at all possible; at least that used to be true!
With the new feature, all we had to do was enter into the "Recovery Restart" screen and press the "AUTO SET RESTART MARKER" softkey. The marker (R) was automatically inserted into the correct position for restart, and we were ready to run. Then simply press "RUN PROGRAM" followed by the flashing "CYCLE START."
To see for yourself, download the FREE 90-day WinMax® desktop trial.
