Christmas Open House Preview
12 Machines, 20 Suppliers and Plenty of Ex-Stock Offers
Pre-Register here
Hurco Europe Ltd are pleased to announce the return of the popular Christmas Open House exhibition on Tuesday 5th and Wednesday 6th December 2023. Opening times are from 9.00am to 5.00pm each day with lunch and refreshments provided throughout the event.
In addition to a showroom full of new Hurco CNC machine tools under power and cutting metal, there is the added attraction that many of Hurco's primary suppliers will be in attendance.
This year, as many as 20 specialist suppliers covering tooling, workholding, CADCAM, metrology, automation, mist extraction, rotary tables, angled heads, coolant and lubrication, probing and machine tool finance will be in attendance. Each with their own small stand. This allows existing Hurco users and potential clients the opportunity to discuss ancillary equipment in a relaxed and informed environment.
Hurco ProCobots will take centre-stage at this year's show. This is Hurco's own in-house plug and play automation system for component handling. Now a popular and established product with several successful installations throughout the UK. The main advantage that ProCobots have over other automation solutions is that it is so easy to use. A simple app appears on the WinMax control that needs to know minimal information before the job is set. Changeover times from job to job can be as little as 30 minutes, making small batch automation a reality. There is also the reassurance that the ProCobot is supported by the same people supporting the machine tool.
There will be 4 different 5 axis machines on show with extra emphasis on larger toolchanger capacity, represented by the VMX30UDi-60ATC. The 60-station option is now available on the SRTI range, as well. In addition, there will be 2 Hurco CNC turning centres, including the TMX10MYSi​ driven tool lathe with Y axis and sub-spindle. As ever, the majority of the show will include cutting demonstrations on 6 models from Hurco's best-selling 3 axis CNC vertical milling ranges. Sizes ranging from the compact, entry-level VM One to the powerful VMX60i with 1,680mm X and 660mm Y travels and a 12,000RPM 40 taper spindle.
There are a number of ex-demo deals and offers created specially for the show. Including a tooling package worth £8,750 supplied free-of-charge with every TM8Mi turning centre ordered before the end of 2023, or an exceptional 20% discount off the VMX42UDi-40ATC​ direct-drive 15,000RPM, 5 axis trunnion-design machine.
Although the Government's super-deduction scheme is no longer available. 100% allowance means that huge savings can still be made on this year's tax bill for profitable Limited companies. Check out www.hurco.co.uk under News/Finance for detailed examples.
We look forward to welcoming you. Pre-registration is at www.hurco.co.uk
Pre-Register here​​
